So I need to lay a solid wood floor in my hallway and lounge, what's the best way to stick it down? I'm thinking adhesive underlay? Any opinions on this as its something I've never used.... I'm thinking of starting at hallway threshold so it looks straight when I walk in front door. This means I'd be laying from both ends, would this work with the underlay? Thanks
Engineered flooring or solid planks, engineerd flooring suffers less from expansion movement Better to have a floating floor, use a underlay with a built in dpm (moisture membrane),something like 'Sonic Gold' wouldn't glue it down,when you laid the flooring you need to leave a 10mm expansion gap all the way round to allow the timber to expand. A lot of engineered flooring can be laid dry, just clips together, but you can also glue it with a pva glue, but if you ever want to lift it, then it's difficult without damage. I would remove all the skirting, looks neater than using a beading attached to the skirting to hide expansion joint.
Thanks KIAB It's solid wood I'm fitting and yeah, I've removed the skirtings. When you say floating floor, do you mean underlay? Any advice on using adhesive underlay? I was looking at this underlay but no stock in area http://www.screwfix.com/p/acoustalay-250-adhesive-underlay-vapour-barrier-3mm-10m-green/76517 Maybe this one instead? http://www.screwfix.com/p/acoustalay-adhesive-backed-foam-underlay-3mm-10m-green/62317
No, a floating floor isn't fixed down ( screwed/nailed,etc) to a sub floor like concrete, it sits on the underlay. http://en.wikipedia.org/wiki/Floating_floor Don't see the need to use a adhesive underlay, been using sonic gold underlay here, just need to tape the overlap with a alumium vapour tape to maintian the dpm seal. Hunt around might find it cheaper. https://www.buy-carpet-underlay.co....e_flooring_underlay/novostrat_sonic_gold.html
Well that looks like an easier option anyway, and cheaper! Won't the floor bounce though? Do you just glue it together?
As our older members may remember, Audi-evo a floor laying expert, always recommended Elastilon or SF's version for sticking down floors.
Hehe! Half a sleep here,& nowhere near 100% sober, I just spotted my mistake, didn't read his screwfix link correctly, apologies,brilliant stuff Elstilon, screwfix version http://www.screwfix.com/p/self-adhesive-real-wood-underlay/74549
