Does anyone know the best way to fix this? Will a clean and some ptfe tape or a new washer do it? Or is a new connector required? It appears that be leaking from the top. The pipe is 15mm and the thread 3/4
isolate water supply ,drain down, disassemble the fitting .clean up threaded tap tail. fit a new 15 mm to 3/4 bsp tap connector.
