Leaking Conservatory Gutter
Discussion in 'Builders' Talk' started by Beamed, Jun 4, 2016.
  1. Beamed
    Beamed New Member
    Hello,
    This is my first post here and I have looked at previous post before posting.
    So I have a boxed style plastic gutter fitted in my conservatory and they continue to leak in the inside of our conservatory. The gutter fitting looks like it sits inside the building as per images and mainly leaks in the corner especially after a rainfall.
    We have spoken to some people in the building trade and they think it could be aqual pooling and that they can bed / apply some solution but we have to wait until it is dry weather and forecast to be dry for several days.
    Please can anyone give me support in getting a fix, will foam filler work and if so what type or the solution the builder want to apply is there a name for it? Cost effective and quick fix is my goal.
  2. All I can say is, foam filler won't work. It ain't wot it's designed for.
    There are some cracking products out there that will almost certainly work, but you'll need to trace the actual leak first.
    A photo of that gutter/gulley from the outside would help.
    Can you tell where - exactly - the water comes in? Does it 'travel' before coming in? Or does it come in where it likely gets through from the outside?
    That second picture shows what looks like 'boxing in' - is the gullet behind this? Can that boxing be removed fairly easily?
    Really, if you don't identify where the leak 'gap' is, then you'll simply be coating external surfaces and hoping for the best.
  3. KIAB
    KIAB Super Member
    BMC2000 likes this.
  4. Beamed
    Beamed New Member
    Hi
    with ref to Kiab - we have tried to use sealant which made the leak move along the gutter and find a new place to leak!
    How do we check if the gutter has dropped or warping? Also the company that sell Evercryl only sell in pallets ?
    Devils advocate - as far as I can tell the rain is traveling before it leaks and the leak moved along the gutter it is leaking inside our conservatory. Ps what is a gullet and I'm unsure if the box gutter is easily removable
    I need more specific tips as an bit clueless
    More pictures to follow
    Thanks for quick responses
  5. KIAB
    KIAB Super Member
  6. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Sounds suspiciously like the rainwater somewhere isn't actually falling into the gutter, but straight into the box.
    Mr. HandyAndy - Really
  7. Beamed
    Beamed New Member
    image.jpeg image.jpeg Some further images taken from above
  8. KIAB
    KIAB Super Member
    Could be rubber sealsfailed, if it made from seperarate lengths.
    Beamed likes this.
  9. Mr. Handyandy
    I'd check where the water is falling from the flat roof and/or the coping stones wall.
  10. Beamed
    Beamed New Member
    image.jpg Hey please can you see if the lining looks like its separating.
    Sorry guys getting quite technical here but will I need to removing the roof to fix issue or what can I do? It mainly leaks in this section internally.
    I came across this article is this type of work really required!
    http://toucanroofing.co.uk/box-gutter/
  11. Beamed
    Beamed New Member
    It potentially does hit the wall and then fall into gutter , what can we do?
  12. KIAB
    KIAB Super Member
    Clean out the gutter, & paint inside with Evercryl, should seal any leak.
  13. Beamed
    Beamed New Member
    What would I do if th leak is coming via the coping wall / lining not sure the gutter itself is the issue here
  14. Beamed
    Beamed New Member
  15. Mr. Handyandy
    Can't quite tell the space/distance between the underneath of the coping and the guttering, but possibly self-adhesive lead flashing stuck to the wall and laid into gutter, or some form of drip tray clipped from the gutter to under the coping.
  16. BMC2000
    BMC2000 Screwfix Select
    Does the water ingress only happen with substantial rain ?
  17. Beamed
    Beamed New Member
    It leaks when it rains regardless of how much rain
  18. Beamed
    Beamed New Member
    Seems as though it's progressively getting worse especially with the recent rain fall.
