Leaky loo ...... Unusual design ?
Discussion in 'Plumbers' Talk' started by DIYDave., Jun 27, 2017.
  1. DIYDave.
    DIYDave. Screwfix Select
    Hi all
    Firstly, let me say that this loo is in a workshop on an industrial unit that belongs to a mate of mine - so not totally pristine due to the location
    Anyway, I help him out with a bit of maintenance / diy from time to time. The toilet is in two parts (unusual to me) and is leaking from the join
    My mate says just wack some silicon around the join (but he is a total bodger when it comes to maintenance jobs)
    I would rather separate the two parts, clean thoroughly and reseal and join. Don't want to replace the toilet as don't want to get involved with breaking out old porcelain and joining to cast collar
    My questions are -
    Best way to separate two sections
    What are they likely to be sealed with
    What to make new join / seal with
    Floor is being pulled up as it's painted laminate which has had it and walls will get a lick of paint. It's a workshop not a palace but leak needs sorting and tidying up
    Any help / advise gratefully received guys - thanks
    KIAB likes this.
  2. koolpc
    koolpc Super Member
    Its on a wall!!!! :p
  3. KIAB
    KIAB Super Member
    Old S trap pan, it might be fitted into a clay pipe socket.
    Cut your loses & fit a new pan, a lot easier than trying to get a perfect seal.
    BUT, Stixall or Plumbers Gold sealant might work.
  4. nigel willson
    nigel willson Screwfix Select
    Never seen one of them. However from what I can see they've made it in two parts so that you can change the angel of connection. Would imagine it needs pulling apart and reselling. BUT May break when doing this, so new one with different set up for waste as they are different now!
  5. KIAB
    KIAB Super Member
    I have.:)
    It's known as a ROTAS 2 PART S TRAP WC, & they ain't cheap.
    A Shires one below.
    And a linky, there fitting instructions as well: https://www.hmjames.co.uk/products/...wls/shires/replacement+rotas+2+part+s+trap+wc
  6. DIYDave.
    Cheers guys;
    Loo is definatly fitted on the floor kools, pic rotated corect way on my phone
    Want to leave S trap and collar alone and separate actual toilet bowl from base (if possible),clean up and reseal
    Guessing joint is made using some form of putty / plumbers mait ?
    Not over confident in tackling this job. The grime doesn't worry me as I'm totally not screamish and actually enjoy cleaning and fixing things. Plus will get looked after by my mate
    The loo doesn't even smell 'pishy' it's mainly water that is leaking, especially when flushed. High level cistern so loads of gravity and force when the chain is yanked !
  7. KIAB
    KIAB Super Member
    I always wear latex gloves, when working on toilets.
  8. KIAB
    KIAB Super Member
    Look at my linky for joining instructions, they use sand & cement to join on outside & silicone sealant for internal joint.
    But, I reckon a modern sealant as mention in earlier reply would be better.
    Do the joint after your mate has finished work, will give sealant overnight or over weekend to dry properly.
    https://www.hmjames.co.uk/images_products_original/Web_Tech_Info/rotas.pdf
  9. DIYDave.
    Thanks all for the input so far
    Nigel - yep realise the loo is in 2 parts and separating them, cleaning, then resealing is my plan
    Want to leave the S Trap and Collar well alone as will turn in to a much bigger job than I want. If the bowl can be separated from the trap section, then happy days :)
    Kiab (The Linkmaster) Many thanks, that's very helpful
    If sealed with silicon or even putty, then I may have a chance to separate
    If sand and cement has also been used - then no chance I guess :eek:
  10. KIAB
    KIAB Super Member
    Many years since I've seen one, but the external sand/cement joint should come apart quite easily, gentle persuasion might help,you say it's leaking,so joint as already parted, internal joint seal shouldn't be a problem either.
    The pan might just lift away from base leaving cement fillet in place, stuff rag down pipe to prevent cement disappearing down it, before removing it.
    Very unlikely to be a putty.
  11. fillyboy
    fillyboy Screwfix Select
    So do I, where I go wrong is forgetting to take them orf when I stop for me sandwich.
    I would have thought twisting back and forth would free the joints, but yeah, 40 year old putty, it will be hard. I think the old school solution would be plumbers mait in the joint which I would prefer in that instance to silicone, but, wasn't there an earlier method using hemp string/rope?, depends on how much play once the crud is cleaned off. We need a plumber older than KIAB's horse to answer this one.
  12. KIAB
    KIAB Super Member
    They are quite clear in the instructions, sand/cement external joint & silicone for internal joint, they never were joined with hemp & mastic.
    Plumbers Gold (from TS) should join it, whereas Plumbers Mait is a non setting mastic & so no good.
    http://www.everbuild.co.uk/plumbers-gold
  13. nigel willson
  14. KIAB
    KIAB Super Member
    A few pennies short of £300.:eek:
    http://www.colouredbathrooms.co.uk/wc-toilet-pan.html
    [​IMG]
    In above photo you can clearly see cement fillet, I'm amazed the toilet is still available, last one I seen was nearly 30 years ago,& it had been in use for probably 30 years then, so it's a old design,I do wonder if they actually sell any nowadays.
  15. koolpc
    koolpc Super Member
    crappy price!
  16. KIAB
    KIAB Super Member
    Even second hand in very good or perfect condition they can fetch several hundred pounds.
  17. koolpc
    koolpc Super Member
    It was a joke my dear friend
  18. KIAB
    KIAB Super Member
    Well aware it was Kools, I always keep a lookout for old toilets like the rota, they make you money.:)
  19. DIYDave.
    Managed to pop over for a couple of hours today to look at loo, also lifted laminate floor as was rotten
    Gave the loo a quick clean over and flushed several times to try and see where it was leaking from
    The S bend has a fine hairline crack around the complete circumference of it which you can just see in the photo. It's clearly leaking from here on every flush - so looking at a new toilet
    As mentioned, this style is silly money so hoping to replace with a 'big standard' :))) loo
    Couple of issues are connecting the toilet to the waste in the floor as it's clearly gonna need some engineering
    Waste from floor is glazed clay with toilet waste cemented in
    Any further help would be greatly appreciated guys - many thanks for your time
  20. KIAB
    KIAB Super Member
    Post 3, I said replace ithe toilet,the floor, is it concrete.
    You need to cut off clay socket to start with.
