Hi Lads, Done Lean-to's before but what's got me stumped is a boundary that is wider at one end than the other: down side of house is 5m long, 1m58cm one end & 2m28cm the other (looking at the area, the right side of shed runs along side of house-Left side varies in width). Height isn't a problem but could do with some advice about which way to run the clear corrugated plastic. I was thinking of staggering the shed in 1 or 2 points and running the corrugated from house to the side. Any other ideas?
Nearly always away from the house! You can cut the corrugated across at an angle, no problem. Mr. HandyAndy - Really
