Hi For the first time I am going to installing LED under bench lighting. I didn't realise that this subject in itself. Should I use 12 volt or 220 volt? Where is the best place to get the strip from. What I have found so far can only be cut into 1m lengths although I believe some can be cut into 100mm lengths. Any advice appreciated. Thanks.
Have a look at loox 2043 12v led comes in a 5m roll you which you can cut every 50mm. In the kit you get 1 transformer, 1 roll of led and one 2m connection cable then you just have to buy the extra link cables/diffusers and switches for it to meet your needs.
I have used tons of the stuff, under pelmet, back of the van, front interior after ditching the glow worm courtesy light and my Mobile disco 230V 2A trailing power supply (laptop looking) and a 12VDC output
