Hi, I have no kitchen light power. When checking in behind the switch I see there are three red wires connected to a two switch control. Three black wires connected together into a small jb. The three green wires are again connected and connected inside the housing to a point for earthing. The light fitting in the roof has standard green , brown, blue wires. Can someone suggest what I need to do?
I have removed the fuse from the fuse box and checked other downstairs lights to ensure this is isolated.
Maybe you are expecting the light to work with no fuse for light in db? In other words if the fuse has been pulled for the circuit the kitchen light is on - then operating the light switch will not energise the said light op.
Excellent Mark - you are following isolation procedures as per H + S legislation, this is on the assumption that you have proved dead supply,. I don't know what's wrong with the light, but ave a good day m8..
You need to explain what you mean by "I have no kitchen light power." Does that mean that you have tested wires and found no power, or just that the light doesn't work, or what? And is it a bulb or fluorescent tube type? If it is a fluorescent, have you swapped the starter for a known working one? Mr. HandyAndy - Really
