Hi, i have hung this paper but there are awful lines showing when viewed from one direction. As you can see from the first 3 pictures the paper looks fine but on picture 4 you can see the awful lines. The pattern even shows some lines where there is not a join but the joins look especially bad. I know all paper will have lines at the joins but you rarely notice them. These are the first thing you see and look worse than the picture shows Paper has had two days to dry now. Is there a solution to this or anything i have done wrong?, or is it just the paper?
