c,mon X ive explained clearly enuff,im not gonna tell the customer,by the way the fixed fuse unit u paid me to install is not needed,ever so sorry old chap,ur gonna have to use the socket u asked me to install for your garden heater for your lights now...dont worry u can wear an extra jumper!!!!
I dunno Acca..already know how to do my garden power..got excellent advice from Sparkin quite sometime back now..
Anyone else getting a feeling of 'déjà vu' ? Mr. HandyAndy - really No, but it does seem very familiar..
It aint that hard or r u on a wind up? There's only one person on a wind up, and its acca... I'm sure (fairly anyway) that a NAPIT member could have such a lack of understanding about so many issues.. If however the lack of knowledge is a reality, I have heard that the NAPIT telephone help line is quite good.
Typo... I'm sure (fairly anyway) that a NAPIT member could have such a lack of understanding about so many issues.. I should of put 'wouldn't'.. instead of 'could' But then again....
Anyone else getting a feeling of 'déjà vu' ? Mr. HandyAndy - really Ur correct it is the same job,first of all the customers own lights were not for outdoor use and thn i went on holiday! Wether i plug this harness into a socket or hardwire it into a fused outlet is hardly an issue...im the one with loads of work btw,and X i did call Napit and they say it aint a problem so stop being so high and mighty....
Acca good to have you back, now Sit back relax and listen to the A trax http://youtube.com/watch?v=HfjZM86Yy-k&mode=related&search=
X i did call Napit and they say it aint a problem so stop being so high and mighty.. Moi ? I'm just pointing out that there is an issue with your line of reasoning in this matter and with some others... Think about it and sort it... or ignore it, I care not.
Hi m8,did u see my pics? And tell me i aint doing anything wrong by wat im proposing in this thread,surely..... Good tune...
Im ot ignoring it X,its just u seem to be cryptic and dont say exactly wat is wrong with my method,yes an extra socket wud be ideal but rightly or wrongly i have already fitted a switched fuse outlet and want to utilise it.Tell me what is specifically wrong,or the broken regs and i will concede...if not theres no need to make insinuations into my professionalism which i take seriously...
theres no need to make insinuations into my professionalism which i take seriously.. I'm glad I now have your full attention.. "All harnesses have electrical insulation rating Class II (double insulated)" "All rubber festoon harnesses are fitted with a 2P+E BS60309, IP44 rated plug" So if you remove the fitted plug and then convert the to become fixed wiring... what happens ?
theres no need to make insinuations into my professionalism which i take seriously.. I'm glad I now have your full attention.. "All harnesses have electrical insulation rating Class II (double insulated)" "All rubber festoon harnesses are fitted with a 2P+E BS60309, IP44 rated plug" So if you remove the fitted plug and then convert the to become fixed wiring... what happens ? I guess u have compromised the integrety of the harness,but me fused outlet is ip 66 and i will use same fuse...or have i missed the point again....?
Fixed wiring. I will be honest and say im not sure wat ur getting at,i dont know everything..so just tell me in black and white cos i got a few jobs to do today and i want this cleared up...
