Trying to install a light in my loft - easy right - NO its not. The closest ceiling rose has one cable (earth, live and Neutral) running into it, the switch for this light also has only one cable (earth, live and Neutral) in it running to the floor. I figured power must be at switch so i ran a cable down to it (live to live, n to n and e to e) and took this to a switch in the loft which then runs to a light fitting. Now the loft light only comes on when the downstairs light is on and both downstairs and loft light flicker. I earlier tried to power from the ceiling rose but it just tripped the fuse. What am I doing wrong? was hoping to floor loft this weekend but cant do it in the dark!! Thanks
If there is only one cable going to the light and one cable going to the switch it means that there is probably a junction box somewhere where the permanent live stops and then splits off to the switch and the light. You need to find the permanent live to power your loft light.
Hold on. You can't have a ceiling light with only one cable in it, and the switch to that light with only one cable in it. Mr. HandyAndy - Really
You can, if there is a junction box /joint elsewhere, as Mr Sen said. The lighting radial is at that junction/joint, live feed goes out to switch, returns, joins to light feed, neutrals etc are just connected through. Come on Handy, keep up lol.
One cable, two live cores, live in from rad, live out to light, I am actually assuming, as one would, that a cable consists of two/three cores, and not just a single, though.....
Yeah i was just replying, but thinking before I spoke(again!) Oh I think I get it. so would explain the OPs prob. So it's live red from JB to switch, live black from switch to JB. One cable. Op, connected same live(twice) to another switch. Light just gets one live to both terminals(live-filament-live) that's why it don't work properly.
