Hello I am looking for a 2 Gang Dual Surface Moulded backbox I have found a Galvanised Steel Dual 35mm 48234 and also a Dual Dry Lining Box 22772 but not one Surface like this one http://www.sparksdirect.co.uk/2-Gan...ET-Ultimate-White-Moulded-GU9D25#.U1aAU0lwaHs do you have any like this in stock if you do can you post the Product Code or url to it as I need it for LAP USB Charger Grid Module White Product Code: 69526 LAP 1-Gang Front Plate with Double Module Aperture White Product Code: 42092 LAP 13A Switched Fused Connection Unit with Neon White Product Code: 79474 any help on this will be good thank you J.McCabe
I dunno if Screwfix stock them, or will stock them Nod tbqh..they would probably do you a deal on a consignment of say 1000 units specifically ordered for you on a one off basis - av a word with your local Screwfix manager and see if you can haggle a price/negotiate a deal..
Hi I have just been looking on our website and it appears we do not stock the surface boxes only these duel boxes. http://www.screwfix.com/search.do?fh_search=Duel+box&fh_view_size=20 We are unable to arrange any single order for a single customer. For future reference if you need assistance about a product or availability of goods email online@screwfix.com or call our customer service team on 0500 414141 Peter
Peter, sorry to be picky but you are, presumably, representing Screwfix so I must point out that a duel is what I feel like challenging your counter staff to when I go in for an urgent everyday item only to be told that it is out of stock but that they can get it for me tomorrow. A dual surface box, however, contains two single outlets. Hope this helps with your future product searches.
NoOhm, if you reads his comment carefully you see he stated screwfix does not supply them however in his search there is drylined dual 2 gang box. The OP want a surface mount, so thus he have to go elsewhere to buy the dual 2 gang surface box he wants.
I don't understand why he opens up a thread asking for a dual surface box and then links to one. Can't find one like this. Bloody strange if you ask me. In fact there is no such thing as a two-gang dual box its just a dual single box, ie a box with two single-gang boxes side-by-side in one unit. It would be just as easy to use two single-gang boxes and mount them side-by-side.
I don't understand why you don't understand why but to the why I have been shopping with screwfix from 1998 and want it from them not from a place i have never bought a item from before. as to "In fact there is no such thing as a two-gang dual box its just a dual single box, ie a box with two single-gang boxes side-by-side in one unit." yes it is a dual 1 gang box but if you look around at websites that list this item most list it as a Surface Dual Box 2 Gang even here and link in my OP http://www.lightupuk.co.uk/switches...gang-38mm-k2025whi?pk_campaign=GoogleShopping lists it as a Surface Dual Box 2 Gang from MK and if you look at the MK listing for it MOUNTING TWO X 1 GANG http://www.mkelectric.com/en-gb/Pro.../mouldedboxes/dualbox38mm/Pages/K2025WHI.aspx and using two single-gang boxes and mount them side-by-side is not what I want. thanks Peter but I have seen them and not what I am looking for as most of the walls in this house are concrete.
Better? You turn in to a right diva when your challenged. Go and eat a Snickers! I would buy it from sparksdirect if I were you. Hint: Screwfix don't sell them.
Fit metal dual box onto t'wall with cables and stuff in oval - and then after pva'ing with a what 4 :1 mix, bond out whole wall to a what 40mm depth (use 40mm runners and pull derby off of them) and then pva again with a 4:1 and while still wet - ''whip on a skim''..you can buy the metal dual's from Screwfix.
