Mapei AquaDefense
Discussion in 'Tilers' Talk' started by mumbley joe, Oct 14, 2014.
  1. mumbley joe
    mumbley joe New Member
    If you are doing a wet room or a shower would this AquaDefense be all you need to put on new plaster to waterproof it all before tiling? It is fresh plaster but a few months old now but does it need priming before using the AquaDefense? ta
  2. StevieSteve
    StevieSteve Member
    I've never used it, I use the other type of Mapei tanking. Best read the instructions, ask in-store, or ring Mapei technical.
  3. greg12
    greg12 New Member
  4. jimson
    jimson New Member
    It may be a good idea to wire brush walls before applying aqua defence.I presume you are doing the work
    yourself.Use a cement based adhesive,slow set flexi will do the trick.Do not stick the tile spacers into tiles
    use them so you can retrieve them when tiles are dry ,for perfect perimeter cuts try the tile clip pro over on ebay.
