Hi all After watching a vid on you tube UH It shows he has a rubber washer under the tray and a washer on the top. I haven't got a rubber washer for the top, do I need one? The plan was just to silicone In. Do you recommend a washer for the top? Any advice would be great, just want to cover all areas
Never had a top washer on all the ones I've done either. I normally put a bit of silicone on both faces of the bottom washer and a bit for the top piece. Never had a leak yet.
