Hello all. New to the forum (and attempting lots of diy at the moment). Looking for some advice please. We are replacing the skirting board in our house. We've bought 4.3 meter lengths of primed mdf skirting to cut and fit. Some of it is quite bowed, so we're not sure it'll stick to the walls properly (we're going to screw any stubborn bits too). Is this normal or should we ask the shop for replacements? Any tips very welcome! Many thanks, Bernie
I wouldn't see why it would be a problem if it is warped length ways. It will be flat once screwed to a wall.
4.3s of MDF are likely to bow slightly under their own weight, especially if stored upright in the store / yard Timber yards tend to store their timber flat, much better system Just depends how much bow your talking about. MDF is fairly flexible, lay it flat on the floor and with gentle pressure will it lay flat (obviously easier to tell on a hard floor than carpet) If with gentle persuasion it lays flat, then no problem I recon. What product are you using to stick it with out of interest
Don't see how it matters! If your fixing it. Grab adhesive is pretty good then screw too hold. Especially if your painting. Caulk the tops job done. Mitre fix is good for external corners.
Hi Did Dave. It does go flat with pressure. Currently have the "warped" ones on the bottom of all the others to hopefully keep them flat till need to use them. Was told to use grip fill, so got 4 tubes of it. Have 4 rooms to skirt...
Is it gripfill green tube (solvent) or yellow tube (solvent free) If green, and uv not used this product before, there is a technique to using the stuff, especially with long lengths of skirting Main problem is that it "skins over" very very quickly. This can result in a poor bond to the wall and it won't squish out flat between skirts and wall, resulting in gaps Yep it's an excellent product with great bonding properties, just has limitations, especially if not used to using it Yellow tube doesn't have that instant bond but is actually lovely to use, yes really
Thanks for that DIY Dave. So what tips do you have for the green tube grip fill, as that is what I have!? Many thanks
Be quick very quick lol make sure it fits dry properly and then glue up and fit also pins to hold is easier than screws as screws will need pilot holes and to be filled and sanded where as pin holes will only need a tiny bit of filler if anything before painting
One tip I can give. Apply to skirting and when pressing it against wall, move it up and down to 'break the already started to form skin'. Mr. HandyAndy - Really
To be honest, my main tip would be to swap it over for solvent free yellow - not essential but I find it so much easier to work with Green stinks to high heaven, skins quickly, messy to use and any excess and spills are difficult to clean, once skinned over can adversely effect bond, good instant grab though. With long lengths of skirt, you need to apply to board and attach to wall really quickly, two of you working together is better Yellow stays lovely and creamy whilst your using it, any mess cleans up with a rag and warm soapy water, no smell, squishes out behind board, has good suction but you don't get that instant bond. Best to either wedge skirt to wall with some timber, bricks, paint pots or other whilst adhesive dries or if your using a few screws and plugs anyway, then no need to wedge You can use any excess that pushes out the top of the skirt to fill gaps but it can shrink and crack as it dries. Much better to use any excess on the next bit of skirt and caulk along the tops to fill gaps. Large gaps fill well pushing caulk in with a paper scraper, you may need a 2nd fill once dry as caulk may shrink back a little. Finish with a tiny bead of caulk along tops of skirts and remove excess with a damp finger. Finish with a just damp rag. Like the yellow gripfil, caulk is water soluble so easy to clean as you go Good luck with the project
I used this when I fitted my MDF skirting, I had a wall with a bow in it and it stuck it no problems, I haven't used any other form of fixings just this. http://www.wickes.co.uk/Wickes-Ultimate-Instant-Grab-Adhesive-White-290ml/p/156744
Many thanks to you all, great advice for us novices Toss up between instant grab but have to be damn quick or not so instant but more workable....think I will go for green on the small sections and yellow on the long sections... Thanks again
Yes Dave! I Recall scrubbing the green off laminate floor praying it will come off lol. Might give the yellow type myself a bash next time. Good post
I've seen the MDF skirting but found wood to be cheaper other than MDF been completely defect free rather than with knots etc what other reasons is there to fit it??
That's pretty much it, DNR - smooth finish ready for painting, knot-free, less likely to warp ( ), doesn't move as much with moisture. I wonder if that's the issue that Bernie had - the MDF stuff is usually primed on the facing surface, so if it's been kept in a cold damp building it might have absorbed more moisture through the unprotected back? I wonder if it bowed outwards towards the ends of the lengths - ie concave as you look at the finished surface? Anyways, chust to agree with the above - solvent-free stuff is soooo much better to use, with the sole proviso that it doesn't 'grab' as firmly instantly. Bernie, either way, make sure your wall (fresh plaster?) has been fully painted first, or else it'll both absorb the solvent making the adhesive thicken more quickly, and it might even fail to grab as the dusty top layer of plaster simply rejects it. Solvent-free is a nice stuff to use: a good bead along near t'top and t'bottom, and a wiggle in between for good measure. Make the top bead close enough to the top edge, and thick enough too, so's a bit squeezes oot along the top edge against the wall. If there are any gaps where it hasn't squished oot, then run a bead along there as soon as it's in place - wipe your finger firmly along that edge to squeeze it in, and to remove the bulk of the excess. Then wipe it over with a damp cloth. With a bit of luck - ie if there are no large gaps - then you'll end up with a finished seam ready for painting; no decorator's filler required. What Sol-Free does require, tho', is preparation - position each length dry first, and make sure you have either clamps in place to hold it wherever it wants to spring oot (if you have bare, unfinished floors, then simply tack a wood block in place to hold short battens that can be levered into position against the skirting to hold it firmly. Don't forget that dry run...). Or else get some 2mm panel pins of whatever length you need - you can get them 50mm long at least. Half-hammer them in to the MDF wherever they are need to hold it in place whilst the S-F sets, and then knock them in to hold. If you want you can leave them not quite 'home' and remove them afterwards, with chust a teeny hole to fill. Or just blatter them home and be done... To joins lengths of skirting mid-run, mitre the joins - you'll get a much better (stronger and more invisible) join. Solvent-free the joints too, including the corners - use a sharp edge to scrape away the excess to follow the profile of the skirting.
Many thanks for all those tips! Never thought to use a batton to hold it in place... Just need to practice my scribing now! Hoping we don't need joins as max length is 4m.. So as long as my math is good should be good, but will remember that tip. Thanks again
