Hi all, Just fitted a new Mira Orbis shower. When switched on the display flashes constantly and says low. It also never gets warm. I checked the water pressure going in and it's fine. I took the inlet filter off and this was empty and clean. Any ideas what else it could be? Cheers SteveSteve
Hi Do you have mains or gravity fed cold water to the shower, Please attach link for the shower you have installed Kind regards Tony
Hi it's mains fed: http://www.mirashowers.co.uk/onlinecatalog/detail.htm?productNumber=Orbis 9.8kW There's plenty of pressure going into the shower, I disconnected the pipe and water was flying out.
Hi Did you follow the commissioning procedure in the instructions? Ive just had a look there's about 10 steps, Have you placed the shower head at its lowest point?
Yes followed them. The temperature part never actually displays in step 6. The display just flashes and says low.
If your certain you have followed instructions, call there tech, they are the only experts regarding the correct operation of their product, if it's faulty they have an after sales team who can attend free as long as it's not an installation or commissioning fault
I've never installed a Mira shower but I do know that the triton ones that I have put in have a purge pin on the circuit board that needs to be moved in order for the shower to work properly. Hope this helps Mike
