My house is a strange shape and i'm putting up coving and picture rails. Most if not all of the angles are either greater or smaller than 90 degrees. What type of mitre saw should I use for these types of angles?
It's more to do with the measuring rather than the cutting, measure the angles and cut the correct angles to fit your house it takes some skill to get good at it and isn't often done even by professionals but looks brilliant if you get it right, the new way is cut all at 90 then fill and pack when you need to (experience of new builds compared to old skilled building)
[QUOTE="DNR Plumbing, post: 1384858, the new way is cut all at 90 then fill and pack when you need to (experience of new builds compared to old skilled building)[/QUOTE] I'm old school, still use my Angle Finder protractor for transferring angles to set up my mitre saw for cutting, I must learn your new way
Thanks for your replies. I can find my angle with my protractor etc but I cant cut the angles accurately by hand so thought id purchase a mitre saw but which one is best? They all seem to only have set angles that don't match the ones I need - or am I just being a bit dim???? Some obtuse angles have massive gaps if cut at 90 degrees so packing isn't really an option in these cases as it looks rubbish.
I'm old school, still use my Angle Finder protractor for transferring angles to set up my mitre saw for cutting, I must learn your new way[/QUOTE] That's how it should be I've seen some bad work in modern new builds but after 20 tubes of caulk and a good decorator the vast majority of the general public wouldn't know how bad the build is
Google "magic mitre" angle finder and cutting jig all in one http://www.ebay.co.uk/itm/Magic-Mit...-in-Seconds-/290600431814?hash=item43a922b0c6
For less than 90 deg most mitre saws have a locking facility other than the idents for the common angles, for over 90 deg it depends on the saw, you can get one that goes up to 120 deg but you pay for it.
From our hosts this is the cheapest I could find and will do 104 deg. Look around though. http://www.screwfix.com/p/hitachi-c10fce2-255mm-compound-mitre-saw-230v/3351j
If your not doing a large job then maybe consider one of these. Had one of these when first starting out in woodwork. You wont be able to cut coving on a mitre saw as it will end up being damaged.
Trend angle finder. Pretty good automatically halves the angle for you. Put on the chop saw happy days. Interested in how you would manage to fill it and still look ok. Time is money I suppose
The trend mitre fix you mean? I have used a dewalt chop saw that goes past 45, I had this problem with skirting once think it went to 43.
I was talking about the hand powered one, as usual I forgot to press the post reply button when I first tried to post.
