monoblock flexible tails 500mm
Discussion in 'Plumbers' Talk' started by pr1970uk, Jul 17, 2008.
  1. pr1970uk
    pr1970uk New Member
  2. Captain Leaky
    Captain Leaky New Member
    Why do you need a 500mm hose? You can always join them!
  3. HOTDOG ø
    HOTDOG ø Active Member
    Check the tap tail size - they vary too. Most merchants will stock 300mm tap tails and you can then extend them with pipe etc. Or contact the manufacturer of the tap. ..and be careful next time!
  4. Mr Ian
    Mr Ian New Member
    The 500mm ones I bought the other day from SCREWFIX! might do the trick
  5. pr1970uk
    pr1970uk New Member
    Hi
    I cant join them because the monoblock is 330mm high and there isnt room inside the tap to allow you to join two together.
    And the reason I didnt buy a 500mm from SCREWFIX is that they dont sell monoblock tails that long, only normal flex hoses.
    thanks
    Paul
  6. pr1970uk
    pr1970uk New Member
    Hotdog, thanks. I might consider the pipe extension idea if i cant find tails long enough,
    Unfortunatly they arrived like this 4months ago and have only just been fitted.
  7. sinewave
    sinewave Screwfix Select
    Unfortunately they arrived like this 4months ago and have only just been fitted.
    Ah yes, there a right pain those dam 4 month warranty's!
  8. pr1970uk
    pr1970uk New Member
    right sarcy bunch on here arnt you.
    gotta fit this by tomorrow, if i wait for a replacement on warranty i`ll be waiting a week.
  9. Mr Ian
    Mr Ian New Member
    Fair point about the 300mm monoblocs - my mistake. BES will have them, otherwise can't you use a nipple??
  10. HOTDOG ø
    Yup! :)
  11. pr1970uk
    pr1970uk New Member
    ok thanks Mr.Ian, I`ll have a look on there.
    Dont think a nipple would work because of the tight space.
    its one of these taps
    http://www.bathroomheaven.com/uploads/Horizotall.jpg
    The connectors are right up inside the tap so space is only enough for the 10mm end to go.
  12. Burt Ralph Hughey
    Burt Ralph Hughey New Member
    space.
    I realise this may well be a dopey question (and I'll probably get slated) , but if the flexi tap tails go right up inside - how do you tighten them up enough to be watertight ?
  13. Captain Leaky
    They only need hand tightening. A common fault is people trying to over-tighten them and twisting the tails.
  14. Burt Ralph Hughey
    Thanks v. much for that ,
    Buuuuurt !!!
  15. strappy
    strappy New Member
  16. strappy
    strappy New Member
    Forgot to add that they'll probably be able to cut the crimps from yours and refit the ends to the new hose.
    For my Merc I had PTFE lined with ss braiding and they re-used the original fittings and it was about a metre in length,all for £6
