Is there any regs saying you have to be at least 300mm away from a window when coring and mounting a 4" extractor fan? I know this is true for a flue, but a guy at work said it's also true for an extractor fan where as I don't think it it. Anyone know? Thanks
Those measurements are if you site a boiler and refer to the flue sitings. The only problem would be if the window has a lintel, and the normal overhang for the lintel is 150mm.
