Hi Everyone I just completed my first project (a workbench) and would greatly appreciate some advice on the finish for it. The frame is pine wood the remainder is MDF. I have trawled the web and the forums here but I am none the wiser. Can anyone offer any advice on the best finish, was thinking of perhaps a clear finish. Many thanks
Think it may look good just to use an opaque acrylic satin (Semi Gloss) paint on the frame and a clear sealer on the cupboard, drawer and bench top.
Thanks Astramax, as I am a novice to paint can you recommend any particular ones please, would be greatly appreciated
Thats good, especially for a 1st project. Is it being used indoors (garage etc) or exposed at all? Is the floor or the air damp or likely to get wet? Is it on show and seen often? Likely to be used a lot and take lots of knocks and abuse, or exposed to oil or anything often?
Hi Jacktrades Thanks for the compliment, in answer to your questions: Is it being used indoors (garage etc) or exposed at all? - In a garage only and not exposed Is the floor or the air damp or likely to get wet? - Air is not damp and not exposed and will not get wet Is it on show and seen often? No, only seen by me and my mates
Dulux Diamond(waterbased) eggshell would be a good choice as would Dulux Diamond clear floor varnish (nice and tough), Seal the knots and apply a primer to the frame, would use Zinsser BIN as this seals knots and would also prime the timber. The frame looks as if its treated timber?
Hi Well done. Feel proud , YOU DID IT. Its great when you get a project up and running. Maybe show the kids what daddy did in years to come. My Grandad made a school desk in circa 1938 for me. From Tea Chests, No BQ then. My kids played with it. 56-53 now Grandkids also. They are 18 and 20 now. Its in my sons loft waiting of the Great Grandkids. Time flies. Paint is not my expertise. LOL. Johnny M
Thanks Astramax, I'll look at ordering them tomorrow, not sure if the timber is treated but can check with my local timberyard Thanks for your advice
Thanks Johnny Yes I did it at last. Dad was a builder but told me not to get into that game, how I wish I had.
Looking good. Nice job. A couple of suggestions. You will probably want to bring the vice in a bit from the end (in past the leg) this will reduce vibration when using the vice and increase stability. Also, I usually pop a couple of 200mm wide strips down each side, this means the workpiece can lay flat and tools/shavings/screws etc dont get in the way. Just suggestions though. This is a nice looking bench... I'm liking the drawer.
I had thought about moving the vice in as per your suggestion, but it seemed so difficult as I am new to all this, maybe on the next bench I will. The drawer was an afterthought and I viewed a lot of videos to understand the procedure on fitting it, alas its not perfect but... oh and it was from a damaged basin cabinet that I had in the garage Thanks for all your suggestions which I will definatley take on board
Is that a good thing or a bad thing, or as I am guessing, it depends on whether or not it's in "wet" environment.
Thanks to everyone who has replied to my post, I really do appreciate your input. Now I know why I signed up to this form Cheers guys
May make a difference if it's treated timber and you want to paint it - not sure you can paint it if the treatment is 'fresh' Anyway, it's a workbench, looks great really, well done, sweet build If you paint it, all those knocks, scrapes, inadvertent cuts, gonna make it look scruffy in no time at all.... it's a workbench, clue in the title ...... not a piece of Chippendale furniture in your drawing room What's the top made from ? Sometimes worth fitting a 'sacrificial' top over the bench with a few screws, something like 12mm mdf When that top gets damaged, you can unscrew and flip over. After 2nd use, chuck and replace as cheap
That looks lovely. But it's a workbench, you're supposed to work on it, no? It's supposed to have battle scars, isn't it? I'm not dis'ing it, I'd be proud if I'd made it. It's much nicer than my workbenches (old desks) and shows attention to detail, but why perfume a violet? To protect it from oils/solvents/other crud I'd probably cover it with something. Me? I'd just use anything I have lots of. Oil based stain, gloss paint, varnish, whichever cheap tin is handy and would stop it being too absorbent without me needing to spend money. ...but, there again, I am rougher than a toad's back.
