Hello Guys First post,and as is always the case, i need a little help. My name is Brian and i am from Glasgow.I hope i have posted this in the right section.I am needing a little help identifying and naming some work i seen in someones house. Last week my wife and i visited an interior designers house to pick up a couple of Sofas, that she was selling.She had a natural stone effect walls in her hallway and in a lot of her rooms.My wife fell in love with it,and we enquired as to who done the work and what it was called.Unfortunitly it was done 16 years ago,and she has forgotten what it is called,never mind who done the work. It has a textured plaster feel to it,and she said they got the stone effect using masking tape and then peeling it of.I have googled every variation of textured plaster stone effect walls i can think of,but not found a name for it,never mind somebody in the Glasgow area that can do it.I have a couple of photos below of her walls,to give you an idea of what i am talking about....My wife and i actuly thought it was tiles,until we turned up to view the sofas.Any help identifying this product,and what its called is much appretiated guys. Regards Brian
I think it's called Venetian plaster, some of it can be highly polished and some is textured. I saw some on a plastering course I was on and I was amazed at how good it looks.
Wallpaper works for me, unfortunately my wife has different ideas, lol If you meen the photo of the custom stock or air rifle action....An old hobby that i lost intrest in a couple of years ago. Sold the stock on ebay,a long time ago,the buyer never left me feedback,so was a little reluctent to delete photos...the action was also sold around about the same time... Regards Brian
Just googled it mate, certainly looks like it.Now i have a starting point, all i need to do is find someone who can do it.Thanks for the info, i am further on than i was yesterday. Cheers Brian
(If it's been over 40-odd days since you sold the gun stock on eBay, the guy has no come-back - I understand) I suspect the cove - or blone - who did the stone effect was someone who specialises in that kind of stuff, possibly 'marbling' effects and restoring old coving. That wall effect is very simple to achieve in theory, but needs someone with the right artistic skills in practice. As you already know, it chust involves masking out the grout lines and skimming over with a suitable plaster finish, and very possibly it is chust finishing plater wot's used. The skim is given the required finish - I don't know what finish that wall has - is it an even texture such as achieved by dabbing the almost-set plaster with a coarse sponge or scouring pad for instance, or is it a scoured/dragged finish to suggest a carved stone finish, or what? But what then makes it work is the painted finish - and I suspect it is painted, at least the dark shaded bits. I can't think of any other way to get that colouring and shading. Have you seen a good quality painted 'marble' finish? You cannot tell it from the real thing from a foot away. Y'know what, Brandon? You and t'other 'alf can do this . Get a stiff board of some sort and practice the technique first. If you don't want the whole plaster finish to have to be painted to get the base colour - ie if you want to restrict the painted part to chust the 'highlights' - then you need a suitably-coloured plaster to start with. You can get different colour plasters - even chalk-white - to start with, and add small amounts of coloured matt emulsion to get the shade you need (use strongish colours so that you don't have to add so much to get the shade you want - ie: if you added light 'magnolia' emulsion to get a light beige finish, you'd have to add a huge amount of that paint to get the colour, and that would possibly weaken the plaster mix; I'm sure a dollop of matt emulsion won't affect it at all...) Another option is to use cement-based grout. I had to use a 'limestone' finish grout many moons ago, and I think it might be close to what you are looking for. So - base wall colour. Mask out mortar lines. Skim over a 2-3mm skim and level it out fairly well - but don't dawdle on this stage too much. Remove masking tape at this stage, I think. Use scouring pad/sponge/brush to get the finish you require after the skim has begun to set - you'll probably have a 30 minute window to get it done. So, for a large area, get it all quickly textured to what you want - both of you going 'ammer and tongs. Then go over it again fine-tuning the texture. With the masking tape removed, the edges of your blocks will be softened slightly so will look more natural against the masking tape. In any case, there's no way you will remove the masking tape after the skim has started to set! Finally - and most importantly - post the results on here. (Start with a feature wall in a small loo...) (Or else Yell for things like 'marbling', 'cornice repair', 'period restore' etc - good chance one of these will say "I know a cove who'll do this...")
Thanks for taking the time to type all that out mate. Your right about ebay,and paypal, 40 days then the buyer has no comeback. It was just easier to leave them on, i suppose.Now deleted. Thanks for all your suggestions. I dont think we will be trying it our selfs, not unless the finish is to be red...lol....You do make it sound easy, i have tried a lot of easy things in the past, with realy bad results,lol....Lesson learned, leave it to the guys in the know, or just admit defeat, because it is to expensive.I will search for it later online, and on Yell. Never seen "quality painted 'marble", but i know my wife has, and has said like you, that it is hard to tell the difference. I think i will try a search later on Yell, and online for marble effect.Somebody is bound to know someone who can do it. Many Thanks Again, for you advice, and suggestions. Regards Brian
Its polished plaster its not as hard as is looks just time consuming and plaster is not that cheap i had to do a load for a customer who want a marble look loads of it on u tube Polished plaster is a term for the finish of some plasters and for the description of new and updated forms of traditional Italian plaster finishes. The term covers a whole range of decorative plaster finishes - from the very highly polished Venetian plaster andMarmorino to the rugged look of textured polished plasters. Polished plaster itself tends to consist of slaked lime, marble dust, and/or marble chips (which give each plaster its distinctive look). Polished plaster is mainly used internally, on walls and ceilings, to give a finish that looks like polished marble, travertine, or limestone.
No paint effect needed can finsh with different waxes after could even do it in a shower looks amazing going to do a wall at home when i get round to it
Looks like faux travertine tile paint effect. Something like it here. http://interiordesign.lovetoknow.com/Faux_Painting_Stone_Wall
