im a member from a few years back but can't find my login so I've created a new one. I'm after a kitchen handle if a specific length and can find sites with longer and shorter but not this one. It's 790mm long and 762mn screw centres. I think it's called Boss Bar Range. I attach a picture of it. Thanks
Are you 100% certain of the measurement posted ? • Sizes available: 128mm hole centres - 156mm overall length 160mm hole centres - 188mm overall length 192mm hole centres - 220mm overall length 209mm hole centres - 237mm overall length 256mm hole centres - 284mm overall length 309mm hole centres - 337mm overall length 320mm hole centres - 348mm overall length 359mm hole centres - 387mm overall length 409mm hole centres - 437mm overall length 416mm hole centres - 436mm overall length 448mm hole centres - 476mm overall length 480mm hole centres - 500mm overall length 509mm hole centres - 537mm overall length *709mm hole centres - 751mm overall length *807mm hole centres - 849mm overall length *909mm hole centres - 951mm overall length * 1157mm hole centres - 1199mm overall length
Positive of the measurements. I know I've found those sizes and mine falls between 2 listed. I found one for sale of that size on Amazon but now says currently unavailable
Quite a few sizes on ebay, can you buy the larger length and reduce it to the size you require, fairly simple to do as it would only be one end to alter!
May require drilling and threading to suit but I am sure a local engineering company or even a hobbyist engineer can help.
