Hi, I am looking for some advise on how to replace my current Newel posts, Hand & base rails and spindles. I am ok with changing the Hand & base rails and Spindles, its just the newel post I am unsure about as I don't know how they have been secured. Can anyone offer any advise, I've tried to attached some pictures of what is currently fitted, so hope its worked. Thanks
I agree, but we are changing the internal doors from the current white ones to oak, so wanted the stairs to follow the same theme. We were looking at square newels, oak hand & base rails and spindles which have a brushed stainless steel in the middle.
It's an easy job to do but with kids in the house why bother, give your wife something else to think about.
How easy is it to do, as all the info/videos I can seem to find nothing seem to suit? I'm assuming the bottom newel is secured by screws to the stair case as i've not got floor boards down stairs but I guess the top one is secure to the floor joists prior the to builders fitted the floor boards. To be honest its more me than the wife, she is quite happy with the way it is. I'm also trying to avoid having to rub it down and paint it every time we decorate.
To replace the newels will require a serious amount of butchery, google replacing newel posts and look at the images. Maybe a better option would be to clad the newels and stairs in oak, again google clad your stairs and look at the images to get an idea. And of course you would want to clad the stringer also. Price it up, materials and labour and you may find that you would be better off replacing the stairs
Thanks Wiggy, since reading your post about cladding I've been searching on google. I can find pictures etc but can't seem to find any suppliers of the bits. Do you know of any? Also, as per chippie244 saying I could cut the old newel off and replace the top half and using dowel (or some other fixing method). Is this wise as not sure how strong it would be or would that depend on what method I used to join the 2 parts together?
A good link. Pin newels certianly make the job easier nowadays, a bad habit using broom handles for dowels, but I was shown that trick, over 30 years ago, by a old joiner.
Can't really afford to employ a chippy as on a tight budget, but want to do something with it rather than nothing.
Was sometimes 50mm, but usually nearer 90mm depth,& 180mm long dowel,it depended on the size of the newel used.
I think your first step would be to research how staircases are made, it will give you more of an understanding. What are your skill levels?
So you have no money, no idea and your Mrs doesn't want it and you're persisting with oak ballusters with a brushed stainless steel detail in a tiny house.
