Help Please!! Trying to fit Venetian blinds into the window recess. Windows are uvpc. The gap between the plasterboard and lintel is too narrow for a hollow wall plug. I've gone for drilling the lintel. I've tried drilling the concrete lintel with a masonry bit, but the hole in the plasterboard keeps getting bigger. Been using a heavy duty electric drill. I've started with a 4mm bit and worked up to a 6mm bit. I'm using the red plugs. Trouble is the drill seems to go through the concrete and into an empty space. I'm then having trouble pushing the wall plug into the hole and then lining up the screw and bracket. Taken ages to get now where. And the window recess now has 4 big holes. Not too keen and fixing to the uvpc or gluing a baton on as I've heard they tend to fall down after a time. Has anyone got another method of fitting these blinds? Any advice much appreciated!!
If you're drilling into a lintel you will need an SDS drill, you can stick a batten on with building adhesive but in my house I used a general silicon and they're still there 9 years later or you could pilot drill into the windows with a 3mm drill and then use a 4mm dia screw.
When you say. "The drill goes through the concrete into a empty space" are you sure the lintel concrete??? and not just a steel one, with dot and dab plasterboard on it.
gif post epic fail. Dunno why you've got your keks up your chuff but be a good chap now and sit down and wind your neck in, sweet cheeks.
It works on your laptop because your browser has cached the image . Look, if it's a battle of wits you're after I'm quite willing to wait till you go and get some. I'm away for a fortnight in September though. I'm win95 now btw.
I'd rather listen to Gemini than listen to chippie with his bollards out to be honest. I'm not disrespecting the guy's knowledge by any means, but he's a bit of a pwick sometimes is what I'm sayin'.
