Looks ok to me, as I said though, make sure there's no 'wood' in the way, I have found in the past that even if a roof truss is in line, that by moving the intended light position back towards the house slightly you can gain enough depth for the fitting, reiterate, all in the prep tbh mate.
Ah, so an electrician is actually going to do the work now?, so my comments could actually be taken as 'sucking eggs'?, leave the sparky to do what he's best at, like me, a little bit of ambiguity in previous posts possibly, lol.
Yes an electrician has always been die to do the work. I can drill a few holes and swap an outside light when cables are already in place but laying fresh ones is out of my remit. I'll leave that to the pros.
Got another quick question for any sparkies online. I've found these lights - http://www.screwfix.com/p/aurora-fixed-led-white-50w-240v/31521?_requestid=45061 and was going to have it wired up to this dusk sensor / timer - http://www.screwfix.com/p/lap-standalone-night-sensor-photocell/29790 Now in the instructions for the sensor it states this Incandescant 500W Tungsten Halogen 1000W Fluorescent 250W CFL (energy saving lamps) 200W Which category above would the led lights linked fit into? As i'll be having 7 lights the photocell needs to be able to handle 350w so if the LEDs are CFL the one above would be no good, correct?
Thanks for the reply, so will the above lights be ok with the above dusk sensor /timer? I'm guessing the 50w is a max for this unit and the LEDs are no where near that but I'm struggling to find out the wattage of the bulbs supplied.
Did you mean 50 watts minimum? I doubt whether led's would pull enough current to activate the sensor.
That's a typo on the screwfix site, there is no way those lamps are 50w LED's probably more like 5, but I would check directly with them. Personally I would also try and find out the beam angle, some LED's have a very narrow beam and won't light up the area very well
No 50w max. As in a GU10 50w bulb Max. Surely all the dusk sensor is doing is stopping the current getting to the lights when the desired light level is above what i've set? Or have I got this completely wrong? I can't find any minimum load for the sensor.
Just seen that there are 6W units that are only 12mm deep! Google 6 Watt - Slimline High Output LED Ceiling Light
For anybody who is interested in this my sparky was around yesterday and fitted the downlights. Installation was really simple only taking 2 hours, no joists in the way and went from the fuse box in the garage then into the soffit. Went for 7 lights in total, all centered above each aspect on the front of the house, 3 above garage, 1 above door and 3 above window. This was to give it the most uniform look. They're wired up to a Dusk sensor and switch off after x hours which i can set between 1-8 hours. Really happy with the outcome, here is a few pics.
Nope nothing, the job was so simple. There was already a slight hole in the mortar which we we're able to feed the cable through into the soffit from the garage. Measure up and drill all the holes for the spots, feed cables through and wire up.
Yup now just trying to think of ways we can do the top soffit / gable. Access is quite hard due to the lower roof.
Easiest way would be to take a feed from the upstairs lighting i guess, but bear in mind any issues with them will take your RCD/RCBO out.
I can get a cable up there as it would just spur off from the dusk sensor. When I said access is difficult I meant physical access. It's hard to get up there to drill holes due to the lower pitched roof. It puts the ladders at a very shallow angle.
