Paint over varnish, double checking
Discussion in 'Painters' Talk' started by Brandon1307, Aug 17, 2016.
  1. Brandon1307
    Brandon1307 Member
    Hi Guys
    Will be painting over a varnished window frame/sill shortly.
    Will be sanding it down with medium coarse sandpaper, and using Zinsser BIN
    Primer...Now i have a tin of Dulux white non drip gloss paint sitting in my Garage.
    Would this be okay as a finish coat ?....Just thought i would double check, before going ahead guys.
    cheers
    Brian
  2. Astramax
    Astramax Super Member
    Non Drip Gloss is self undercoating, it will be fine over the BIN but give it 2 top coats as it will look a lot better finish.
  3. Brandon1307
    Brandon1307 Member
    Never new that, that it's self undercoating...cheers bud, will give it 2 coats
    Brian
