Hi Guys Hoping you can help I’m looking to paint my garage wall, they have a very rough type of surface (pics below) it’s almost like a crumbly texture. What would be the best method of painting these? Airless sprayer or good old paint/roller? Will it soak the bricks faster with a airless sprayer Is it best to seal it first, then paint it? Any help much apprenticed Thanks John
Internal wall now, I would use a cheap masonry paint,& masonry brush,which will allow you to work the paint in,without to much mess, whereas a roller will struggle, plus a lot of splatter. No need to seal brickwork. http://www.screwfix.com/p/hamilton-performance-masonry-paintbrush-4/14712
Spraying walls, woodwork, not a problem, but I have no experince spraying bare brick walls, but spraying has so many disadvantages viscosity, overspray, masking off,etc, & you would still to do cutting in with a brush. Long pile roller would be ok, but the spatter can be problem, so well sheet everthing.
The sprayer will, it depends on the peep using it, had idiot at last place spraying walls,my fence was about 10mtrs away had cornish cream flecks everywhere, wasn't happy.
Thanks Chippe244, can you recommend one, its a single garage so am after something small and easy to use? PS i will be hiring one most probably
or if i was to buy one... http://www.coopersofstortford.co.uk...;103993;5253&gclid=CKWZ4uX0sc4CFcyRGwodAtUKWA this any good for a simple DIY, ok not airless though
The one our head painter uses cost about £2000 so I would go for a hire. I'm not at work today but I will ask tomorrow.
Thanks, would it be advisable to use an emulsion paint in these handheld electric sprayers to paint the wall, as im guessing masonry paint would be a lot thicker and just clog it up?
HVLP sprayer like my Apollo will spray, emulsion or masonry depend on needle size, they can be hired around £50 a day. A very easy to use, little mess compared to the old type sprayer. Here we go: http://www.brandontoolhire.co.uk/en/decorating-tool-hire/147-hvlp-compact-spray.html
Hi Guys Just wanted to ask, whats the best paint to use, Ive heard emulsion can crack and peel over the years, a few people have mentioned sandtex exterior paint for the walls? Any preference? Which paint will allow the walls to breathe? Thanks
Sandtex exterior is microporous paint, so allows the wall to breathe, a lot other other masonry paints are micro porous. Looking Sandtex Ultra Smooth they recommend using a brush.
I doubt emulsion paint will flake - it shouldn't. There is no reason why it should. However, masonry will be more durable and is probably the best option here. How to apply? I did my own garage insides - single block construction - and had a similar problem with getting the paint in to the deep texture. So I used a cheapo electric airless sprayer. This did work, but I had to dilute the paint a fair amount to get it to spray convincingly. This meant that, when the paint dried, it wasn't as thick as I'd hoped and the grey of the blocks still showed through. So I used a roller to apply a neat coat over it which was ok - the deep bits were white enough... If you can spray on a thick enough coat, then it will - by far - be the easiest method. Expect to have to apply two coats min, tho'. I suspect using either a brush or a deep-pile roller will be a bit of a 'mare. but you won't know until you try - it might be ok. No harm in trying a 'manual' method first! If using a roller, I'd slap it on thick, and then roll roll roll to spread it out.
If Sandtex would need to be seriously water down to spray it, brush is they recommend ,you can work the paint into all the crevices,etc, just sheet the floor, problems start when you overload the brush with paint, it splatters everywhere. Just had a nosey at the Dulux Weathershield Smooth Masonry Paint & they don't recommend it for use on common or Fletton bricks. https://www.dulux.co.uk/en/products/weathershield-smooth-masonry-paint So, check Sandtex or any other paint is suitable.
Thanks DA, i was thinking of spraying it but like you said I will try it with a brush and roller and see how i get on Will leave Emulsion and give Masonary a try
