Hi! Is it okay to use paste the wall paste on normal wallpaper? Or, can you use normal paste on paste the wall paper?
Paste the wall wallpaper is hung onto the wall without allowing the paper to soak if you use it on as you say 'normal wallpaper it will require a soaking time of around 5 minutes prior to hanging as the ready mixed paste is generally thicker you could thin it depending on how heavy the paper you want to use it on is.
