Plastering over bonding
Discussion in 'Builders' Talk' started by bobbythedog, Jul 28, 2006.
  1. bobbythedog
    bobbythedog New Member
    When spreading finish plaster over bonding from people's experience is it better to have a thin first coat, due to quick drying out time and then thicker second coat.
  2. oldplaster
    oldplaster New Member
    Unibond or PVA first 1-3 mix then heavyer (thicker) mix for first coat then thin mix for tighter 2nd coat
  3. base
    base New Member
    never pva over bonding. you should apply skim approx 2 hours after bonding coat. if its been left longer give a good drink then 2 thick coats. pva should never be used on bonding, there is no need for it.
  4. Biffo
    Biffo Member
    correct Base
