Hi all, I'm having a nightmare, we have builders in tomorrow morning to start extension/renovation & need the outside tap removed. We have a plumber that was meant to come Friday & then today but hasn't turnt up & now at a loss as need it done for tomorrow morning.. Can we do it ourself, how easy is it? Thx
As said, builders should be able to sort it. But, all you need is a Push fit end stop, easy & quick to use, just cut off pipe square, make sure no burrs, & push end stop on. http://www.screwfix.com/p/floplast-flo-fit-stop-ends-15mm-pack-of-2/40223 P:S: Turn off water before doing any work.
May be even easier if the outside tap was fitted with an isolation valve ? A smile and a cuppa for your builder with some friendly chat and he will sort out this "minor" problem for you in minutes Sounds like a large project going on so spending a few ££ I guess, would really expect no charge for this tiny inconvenience (certainly no nightmare in the grand scheme of things)
Any builder should be able to do this as mentioned. It may be to your advantage anyway as I'm sure they'll need access to water, so they can lash up something temporary to stop them traipsing into the kitchen throughout the day.
Why does it need removing unless it's exactly where your new wall is going? If it's just because it's inside your new building I'd leave it till they have finished the job. Save muddy foot prints in the house ☺
Chances are - as Phil says - it won't akshully be in the way for a goodly way into the project, so yer plumbie will have turned up by then. And if he hasn't, don't let him. (Don't the builders have their own plumber anyways?)
If the builders can't work around the tape the easiest way is to isolated the water and check after wards if its off. Then cut the pipe and soften the edge. then use a plastic push fit stop cock on the end of the cut copper. Then turn the water back on check for leaks. if leaks so occur I suggested putting some PTFE tape around the end and the plastic end and then checking for leaks again. Just a quick way to solve the problem
Do not just cut the pipe and cap it this is against Water regulations as you will be leaving a dead leg of pipe containing water that won't ever flow so will stagnate and can poison your water supply
Yeah it's only a very small part of water regs but dead legs (unused pipework) must be removed not just capped where you feel like it you can say remove the "T" where is coupled in repair the main and then leave the dead leg empty but fully disconnected but if you do I would always advise to drain it fully
- got to keep the standards up on the forum! But DNR is not completely correct, a dead leg is allowed where it is not practical to remove it, provided it is not more than 2 pipe diameters long. Ideally, yes cut them out but when it is buried underneath the floor, who is going to check and find out?.
Thanks Friday, I did check the regs and what you say is correct but always best to remove it all so thought that was the best advice to provide.
