Totally unnecessary, anything to make money from peeps. Been doing that for the last 30 years, using 20mm-25mm conduit to sleeve holes through walls.
Yer, what's wrong with poking about with an old wire coat hanger, I mean a few hours wasted fishing for wires, or a nice sleeve to slide them through, no contest????
Ah, but isn't this sleeve fitted as part of the drill, so you drills yer 'ole, and then push the bit through leaving the sleeve behind? Nifty...
I remember drilling a hole through cavity wall in my sisters house. The polystyrene balls should have been put in the walls with a glue but it seems the builder just tipped in loose balls when wall was finished and as a result the balls filled in any hole drilled and with larger holes poured out. I had to inject expanding foam to glue everything before removing the consumer unit and getting a hole through the wall was a two stage job drill hole squirt in expanding foam wait to set then drill it again. So yes with some houses a very good idea.
Wait until you open up a old fireplace! Did a job years ago opening up a large old fire to bring back into use, for some strange reason whole chimmey had been filled with polystyrene ball insulation, ended up with the half of the room about 3'-4' deep in it.
I was called to a house where the old dear couldn't get the heating to work. Time clock was dead. Ventured to the Airing Cupboard to start investigations, opened the door, was met by thousands of polystyrene balls (luckily fairly well moulded together). She had had wall insulation done, and there was a hole through to the cavity in the A/C. It wasn't the cause of the fault
I also did something similar once. Breaking through the bottom of a wall for a large cable to enter at a swept angle. This cavity was filled with the little balls. They all started pouring out of the hole into my trench, but blowing across the whole yard. It was a commercial site, and they had just had the old weighbridge taken out and the 10m x 5m area concreted in. It now has lots of little dimples in it, looks quite a nice pattern, lol.
I came across those little balls a while ago whilst changing a kitchen down light! I took the light out of the ceiling and was greeted by a cascade of the bloody things. It was an old house built around the mid 30's i'd say and some plonker had installed cavity wall insulation where there were no cavities!
Had the downlight overheated by any chance??, this insulation stuff is dangerous in the wrong hands. !!!!!!!!
