Hi, I'm having a new build house created and am considering polished concrete floors, I am a tradesman so not complete novice. I was just wondering if anyone has any experience / knowledge of this type of floor. Does anyone recommend any companies that have a good reputation for this flooring ? any horror stories etc... It's quite expensive but some people have said it's possible to polish the floors yourself as the builder will be laying concrete anyway has the sub-floor ? Any info would be appreciated
Usually no need to power float them as tiles, carpet, wood etc covers it. Unless you want your floors finished to FM2 “Special” tolerance warehouse finish?
That second one is terraza. Very expensive. Dunno what the first one is. Possibly coloured concrete. I slap through concrete every day. Mostly for cow sheds and such like. Not sure I'd want to be let loose in some ones gaffe with the punter looking over my shoulder. That's where a navvy comes in handy. LoL. Though I'm on a biomass project at the moment where a farmer has diversified. I've seen terraza used in milking parlours.
How many times Its polished concrete. http://concretefloorpolisher.co.uk/portfolio-of-polished-concrete/#axzz3jxbQvQ2T
Its not standard concrete. Its some other mish mash they make up. Which isn't stated on their website. Probably about £50 quid per sq/m.
Better things than polished concrete, look at 'poured resin flooring' can be used with underfloor heating, available many colours,in fact any RAL colour that's available, also around 200 flake colours ,& other finishes. http://resinflooring.co.uk/colour.php http://www.sensofloors.co.uk/seamless-floors/
Nothing wrong with resin flooring, if the right product/finish is used for the location. Broke my wrist some years ago on a front porch step at a posh house that had resin flooring smooth as glass, housekeeper washed it, & it iced over.
Hi Phil, You're it is standard concrete, which we ground and polished with diamond abrasives. We normally specify a C35-C40 mix that is well laid, power floated to consolidate the surface and left to cure for 28 days to develop the necessary strength. Unfortunately the customer on that project used a cowboy builder who struggled to get the concrete down and ended up adding additional water to the mix, this effectively turned a strong mix into a soft powdery mix, ruining the finish. Cheers
If you look after the floor with regular cleaning and maintenance (like you would with any premium floor) it will last years and should improve with age.
