Thanks! This is the thing I've got, is that no good then? http://www.screwfix.com/p/titan-ttb278sds-5kg-sds-plus-hammer-drill-230-240v/97533
That's the drill range, it's an SDS-Plus chuck. So you can only use SDS-Plus bits. http://www.screwfix.com/c/tools/sds-plus-chisels/cat5920050 I was on about this beast: http://www.screwfix.com/p/titan-ttb280drh-15-5kg-hex-shank-breaker-230v/67819
I bought an excellent and very heavy post spade from the opposition I bought one of those beasts, really excellent tool, and great value.
No, because there isn's a sds plus clay spade available. Can only find them in 3/4" hex, sds max or spline shank.
Seriously all you need is a grafter and spoons Fitted miles of fencing with nothing else even in the hardest of ground.
This thing is amazing, can be had cheaper elsewhere too if you look http://www.screwfix.com/p/roughneck...gclsrc=aw.ds&dclid=CPe9_MuV19MCFUwS0wod5WsP5w
That's a bit heavy no, wouldn't want to use it all day long, mine weighs half that and cut through almost anything.
It's heavy yes, gives you a bit of a workout but I broke through some really rocky bits with ease just today with it, not sure something much lighter would be quite as effective?
