POTTERTON EP 2002
Discussion in 'Plumbers' Talk' started by NEED-A-FIX, Apr 23, 2006.
  1. NEED-A-FIX
    NEED-A-FIX New Member
    Hi
    The slider switches on my Potterton [b<u>]EP2002[/</u>b] are faulty, I have read that the EP3002 can be a direct replacement as it uses the same back plate. I was wondering wether this was true for the Potterton EP6002 as there is one for sale on e-bay which ends on monday 24th April 2006.
    Would appreciate any advice on this matter.
  2. NEED-A-FIX
    Hi
    The slider switches on my Potterton EP2002 are faulty, I have read that the EP3002 can be a direct replacement as it uses the same back plate. I was wondering wether this was true for the Potterton EP6002 as there is one for sale on e-bay which ends on monday 24th April 2006.
    Sorry I forgot to mention that this is the timer control unit for the Central Heating & Hot Water.
  3. heatyman
    heatyman Member
    The EP6002 is only a single channel time switch so is no good for your needs
    Martin
  4. NEED-A-FIX
    Thanks HEATYMAN for that bit of info. Now I can concentrate on obtaining a replacement.
  5. billsparks
    billsparks Member
    You can replace the 2002 directly with a 6002.
    fyi the 4002 is the single channel time switch
  6. heatyman
    heatyman Member
    Sorry, I'm going dyslexic.
    Martin
