Hi, I'm currently renovation my building that was built in 1896. A solid wall construction 3 brick thick. Building Regs want me to achieve a U-value on my external wall of 0.35 I can't seem to find what my current U-value is on the net. Can some help me, and advice solutions to achieve my target please Thanks Kalp
Thank D.A. Was a good read I read up on some PIR brochures and worked out that I need 50mm Problem I now have is that without thinking I pre bought a shed load of 12.5mm PB and various sizes of timber, so I have to make good use of those. I have spoke to a couple of people about the best way to to do the timber frame: 1. To use my 2x2 battens at every 400 mm,50mm insulation, the cross batten with 2x1, then board after services installed 2. To use my 4x2 timber to build a frame at every 400mm, 50mm insulation, leaving a 25mm "breather" then board after services installed. Option 2 makes more sense to me as less labour required compared to option 1. Would option 2 comply with building regulations??? I've been warned to make sure BR signed off before plaster boarding which makes sense too.
