Hey guys i am a novice after some advice, I want to repair/replace the plaster/render that has fallen off the wall under the window near the floor, My question is what is the best and cheapest product to fill the gap and level it to the wall. The hole is about two feet by a foot about an inch deep. Can i use bonding then tile directly on the top. Step by step guild required please
All sorts of ways to go about this, depends what products you have handy really. Although, no, you shouldn't tile on top of bonding. For me the quickest and easiest solution would be to cut two pieces of plasterboard (will be about 1" thick) and stick them together and to the wall with rapid set flexi adhesive or similar.
