I want to lay a vinyl tile floor in my workshop. The floor is 19m plywood but there are screw heads and small gaps between sheets and some imperfections in the plywood face. Vinyl suppliers have a product called feather edge but only comes in large bags so was wondering whether I could use normal exterior fine filler. Once that's done I probably need to prime the floor to take the adhesive. Again the suppliers have dedicated primers but can I use normal PVA diluted say 3:1? Final question; I will be using F44 adhesive, does anyone know how long a working time this type provides? Richard
Not used vinyl tiles myself but I doubt that PVA is the correct sealant to use on timber floor Reckon it's SBR you want but will need to confirm this before purchase
Could I use diluted yacht varnish as a primer? I've already used varnish on some of the board edges before laying to prevent any possible moisture damaging whilst making the floor. Richard
