Hi - I have acquired some 7" x 2" lengths of timber and Mrs DIY wants me to make some raised flower beds with it. Can anyone suggest the best form of protection inside (to protect against the wet earth) and outside (to keep the appearance of the wood - although rough sawn it has a nice light pine appearance). Thank you diymostthings
You can get clear wood presever. http://www.everbuild.co.uk/wood-care-range/wood-treatments/Wood-Preserver Inside planter a couple coats of Blackjack bitumen paint, will give a planter waterproof liner. http://www.everbuild.co.uk/901-Black-Bitumen-Paint?filter_name=black jack
Thanks Kiab- well I did see Blackjack but wondered if it would be OK with being permantly up aginst wet soil. Thanks for your advice - I will definitely take it!
Read their spec sheet first before deciding &have planter a few inches off the ground, & a few drainage holes in bottom, if decent size you should be able to paint the inside of them with blackjack, & maybebe surrounding underside area. With regards to the Blackjack, many years ago I paint some timber posts with the stuff & allowed to dry before posts were concrete in,neigbour did their fence same time, some 10 years later my posts where still there, whereas neigbours fence posts had been replaced a few years earlier.
After sealing inside of planter you could still you dpm to make a liner, or be a smart *** & buy plastic planter liners & make your planters to fit them.
