Hi, I had to replace this PRV today as the pressure was off the scale. I fitted the new one and it was showing 2.5 bar....but by the evening it had risen to 6 bar. How can this happen? I have not touched the adjuster, I want it to stay at 3. Any thoughts? I cant keep taking it back to the shop!! Thank you
I have checked today that the PRV is suitable for the incoming pressure (up to 16 bar). I have cleaned it, and it is reading 3 bar again. It seems that the pressure increases in the evening - This is for a apartment in a block of flats, I wonder if this make an impact?
Where is the connection for the pressure gauge? If it is after thevalve and before the cylinder, then as the cylinder heats up and the pressure increases. When the gauge is reading high, turn a hot tap, let it run for a couple of minutes, and does the pressure drop? You may not have a problem. Whilst new, these items are fairly reliable.
