Hi. I can only get architrave around one side and top of door frame. The other side will require quadrant bead. Do i butt quadrant up to architrave or do i need to do some fancy scribe. It was like this before but i ripped it all out without looking how it went. Cheers
I don't like it butting up! Depending how much width you have I still try to cut down the arches and 45. Set your margins with square 5mm in and 45 moulding. And 45 head
Get a moulding which matches your architrave. Hopefully bull nose I've never scribed arches, see what others say. Your head top piece will basically have straight cut flush to the wall then at the bottom a tiny 45 The width of your moulding . But will flow round visually look better.
