Hi if anyone could help me with this I'd be extremely grateful. The boiler mentioned has started to have a mind of its own. On either setting hot water or water/heating the boiler fires up on its own and stays on, I know ravenheat is regarded as **** but I cannot afford to replace it and so am hoping it's a particular sensor that I should replace first- thanks steve
hi bit scant on information? but a stab in the dark... the flow switch stuck in closed position, this will be telling the boiler a tap is open, and keep it going? check this out? regards peter
