I have fitted quite a few side and bottom entry toilets but this is my first rear entry type. I am trying to fit a rear entry filler valve to a noken compact cistern, it has a gerberit filler with brass thread but there is no nut or anything to fit the valve to something. there are no holes in the cistern apart from a cutout at the back, so my question is should there be a retaining nut and do you attach to the rear stud partition and it just sits in the cistern. Thanks In Advance.
If you could post up a picture perhaps someone could help. However, it does sound like a plumbing oddity!! Tappy,
