Hi all, I am stuck with the problem of a waste pipe being too low which stops me from installing rail bins system. Making it 3cm shorter would be ok but 5cm would be ideal as drilling a hole in a shelf won't be necessary. Unfortunately I already bought the bins as I was almost sure it should not be a problem but now I had no luck finding any solution, other maybe than US rubber J bend trap for caravans (60 degree max). Waste pipe connectors are joined using adhesive and P-Trap is a typical one with a dishwasher line. How to move it up min. 3cm or shrink it? Any help much appreciated.
Easy! Look at McAlpine FLEXKIT1 or 1.5" Space Saver Trap Inlet (SSINLET1) or Single bowl Kit SSK1, I would think space saver inlet is ideal, but I'm here & not ther to have a nosey. http://mcalpineplumbing.com/traps/sink-kits/ssinlet1c-space-saver-trap-inlet http://www.plumbase.co.uk/mcalpine-space-saver-kit-0-2204118 The space saver inlet can be trimmed to length.
