Hi I am removing a large amount of concrete floor I realise the conventional technique is to break it out using a sledge hammer or jack hammer. What do you think about this as a alternative.... Wet cutting the floor into 3ft squares then drill and anchor bolt said square and jack out each individual square using a engine hoist and wheeling them bitches out Just an idea just trying to make life easier.
hire a mini digger with a jack hammer on it - if it won't fit through the door/opening use the digger to make it bigger
How about setting up an anger management course and get the government to pay you to let disaffected yoof to smash it up for you.
that might work if it was only the size of a paving slab and if they were allowed to throw it through a window afterwards - much bigger than that and they'd be getting sofa withdrawal anxiety
You sometimes wonder if all these stupid posts from new members are just regulars having a laugh but apparently we can't have fun on here anymore
ah you can, but you'll be treated to a holiday if your banter is conveniently misinterpreted such is life
Thanks for that mate gives me a bit of confidence to give it a try. Exactly that but on a smaller scale. I will let you know how i get on if your intrested.
