Hi Guys, can anyone help with this question. I have a bathroom I want to re-tile, as some of the tiles are popping off. Behind the tiles there is a white kind of cement or mortar, its become very dry and I guess is why the tikes are coming off. Behind this mortar is dark grey breeze blocks.. I guess I have to remove all this mortar before I re-tile? There's quite a bit to do and by hand it seems sloooow going and im worried that if I use a hilti power chisel it might crack the blocks.. Any idea how to do it?
I definetrly would not use a hilti on it. Overkill surely. Surely you can just go over it? PVA it first. Im no tiler hopefully someone else will comment.
Not sure about how to remove old tile adhesive. If it was me and I was just replacing those few tiles I get my handy little multitool out. Sorry I couldn't help you anymore. Hopefully OtherS Will Be Able TO throw A Few Ideas
In the pic it looks like other tiles have de bonded themselves. If not, dampen the tile adhesive, leave to soak in a bit, and it may scrap off. Also......DON'T use pva
Are you looking at tiling the complete room or just replacing those few tiles in the picture that have popped off Tiles & PVA - NO
Good idea about the multi tool! The reason why I said to use PVA is this is a repair job. Where I have made repairs in the past I have come back to find tiles on the floor. I then PVA then they stuck firmly on the second attempt. I wouldn't use PVA going on to a fresh surface. Just interested why is wrong?
Hmm I've just done a little digging, there is a huge debate over using PVA primer. Not to open can of worms. But it has worked for me and a tiler suggested it. But now looking maybe its best to look for a recommended sealer. Ask a tile supplier especially if you are going over old surfaces. As they dropped off with me.
As you mention tore, plenty of advice against using PVA as a sealer for tiles Also against many manufacturers instructions There's always gonna be people that have used PVA and had no problems with tiles falling off Luck maybe ? But why take a chance Use the right product for the job, it's not difficult, just a little more expensive than PVA Look at SBR primer. Looks like PVA but chemically different. SBR can be used to prime / seal dusty surfaces, brick, concrete and also timber before tiling
If you're re-tiling the entire bathroom, a decent cold chisel and lump hammer takes them off reasonably quickly. I'd recommend chiselling off as much of the old adhesive as you can and then fixing some proper backing board for the new tiles. If just a couple of tiles, chisel off old adhesive, primer with SBR or a SBR-based bonding slurry, then new waterproof adhesive and grout.
Can't beat the trusty multitool. Might be able to get away with an angle grinder though. Let us know if you try it.
the walls are in a terrible state, im thinking of boarding over the top of it all... what do you guys think? what should I use?
Boarding over it. Removing all the tlies first though right? If you boarding over it just dot and dab it. Should be a pretty straight forward job.
