As OP states he has never touched his consumer unit and probably never seen inside it, by people trying to give advice and lots of different conflicting advice is irresponsible especially when it's to do with electrics.
Your not confident, get a proper sparkie in, will be cheaper than your funeral. Yes, I'm harsh, ain't going to offer an apologie, amatuers & electrics are a dangerous combination.
It's a combined dual tariff CU (actually likely three supplies into that one, as your water heating is on a different tariff to your heaters). With three separate supplies inside there, even with the three main switches OFF, you are going to have three points that remain potentially live. An electrician could safely isolate the 4 circuits for an hours call labour, leaving you to remove the other ends. I would not advise playing inside here, unless it can be isolated at the meter position (which I doubt).
I would isolate all the cabling both ends and find the nearest point of earth in each vicinity I think you will all find this is the correct practice Good reply as well from Lec.
