Hello, First time poster Can anyone help here. I am trying to remove old paint from my mother's metal garage dpoor and having no luck whatsoever. The two products I have already tried have been 1) Tile Doctor 'remove and go' 2) All purpose Nitromors Attached are some pictures Thanks
Is the door powder coated under that top coat, if not then a heat gun, warm and scrape the paint off.
Thank you Phil Tried a heat gun. Didn't make much if a difference and very little bubbling to get a good level off. Not sure what you mean by powder coated? Kind regards
Thanks Malkie Yes. The white coat underneath is fine. Just can't seem to find the right technique to get that top coat off Kind regards
If you are hoping to keep the white coating, don't use a heat gun, it will damage the powder coating aswell, im sorry but I don't know what to suggest that won't damage the powder coating aswell as remove the paint. Are you looking at repainting it??
Excuse me if it's a silly question but if it is sound why are you bothering to remove it? Just flat in the edges and use a coat of good quality primer (Zinsser bullseye 123) and an undercoat, before the finish.
Hi GD66. So... that brown paint is pretty well attached?! So why not let it stay? Give it all a good rub down with - ooh - 180 grit 'wet or dry' paper until the surface is fully 'matted', and then use a primer recommended by the peeps on here - one of these systems that sticks to everything, such a Zinsser or summat. Then a couple of coats of satin exterior paint - again, something recommended by the paint pros on here for durable exterior work - and applied using a mini foam roller to get a finish with the very finest texture which will look as 'pro' as the original white. Ok, you'll need to apply the paint with a brush to 'get into the groove', but then finish off with the roller (if you want).
