Replacing a big rusty gate
Discussion in 'Builders' Talk' started by Iron_Mike, Jan 8, 2017.
  1. Iron_Mike
    Iron_Mike Active Member
    Hi,
    I have this rusty old gate I am try to fix.
    I think my best bet is ripping it off and starting again.
    Any advice on the replacement stuff I should get would be great.
    Thanks
  2. koolpc
    koolpc Super Member
    Dynamite the old one first. Thats a must! :p
    CGN likes this.
  3. Phil the Paver
    The frames of the gates doesn't look to bad.
    The wooden posts are knackered, I would fit RSJs in their place, welding the existing hinges on to them.
    Iron_Mike likes this.
  4. Phil the Paver
    What are you going the do with the other one. :D
    CGN likes this.
  5. CGN
    CGN Screwfix Select
    Def start again all depending on what you expect from the finished outcome asthetic wise and budget etc. With big gates, you need good strong posts and proper diagonal bracing on whatever gates go back in. Design and work around your new gates and bring the fencing and posts to them.
  6. CGN
    CGN Screwfix Select
    Classic gates them...just need a bit of tlc and a coat of paint!
  7. Astramax
    Astramax Super Member
    Replace the lot, sell the old gates to a scrap merchant!:eek:
  8. Iron_Mike
    Yeah the previous owner installed them, not me.
    Not looking for an amazing gate, just a basic gate that isn't falling apart.
  9. sospan
    sospan Screwfix Select
    Useful video - helps a lot
    As Phil says above, I would go and get either an old RSJ or Box section and replace the posts. Shouldn't be too expensive to get some knocked up by a mate with a welder or steel fabricator. I would get some spring load jockey wheels fitted to the centres
    Joe95 and Iron_Mike like this.
  10. Iron_Mike
    Thanks
  11. Iron_Mike
    In regards to the materials I need, how much do you think I will need to spend?
    Seems that I will need a couple of RSJs, new hinges and new gate frontage. Potentially jockey wheels also.
  12. KIAB
    KIAB Super Member
    Look on Ebay for rsj's, box section might be a better option for mounting hinges, can find them cheap, also try Freecycle,Freegle, that's how I got one for my previous place.
  13. Iron_Mike
    Thanks KIAB, will look on the sites that you recommended.
  14. KIAB
    KIAB Super Member
  15. Iron_Mike
  16. sospan
    Try a few salvage yards or scrap dealers
  17. Iron_Mike
    Will do
  18. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    I dunno, looks like the hinges are salvageable and if you are gonna get the hinges welded to RSJ you can have that bottom right bar welded back on to the gate too. Good to go! Cost=welder and RSJ x 2 + fixing into large hole.
    Mr. HandyAndy - Really
  19. Iron_Mike
    Cheers Andy
