Hi, can someone please help me. I have a simple CH system which allows you HW on its own (gravity) or CH&HW together (pumped). This has been run using a Sangamo 410 F4 controller. I presume the system is designed so that if you only call for HW then the boiler gets sent a signal and it heats the tank through gravity (there does not appear to be a cylinder stat). If you call for CH&HW then I presume it sends a signal to the boiler and one through the room stat to the pump. Is there a simple replacement controller? Sangamo recommended a 31033 but when I fitted it, the boiler got no signal when it was switched to CH only the boiler obviously got no signal. From what I can see this controller is not correct. Thanks
I'mn not familiar with this programmer, but the system is basic, so shouldn't be difficult to weork out. Looking at the following PDF, there appears to be a couple of tappets |(slide switches) to engage the heating program. I guess you remove the top cover, and find these below http://sangamo.co.uk/web/FILES/ProductDataSheets/DS_F_0001_B_200631000.pdf
