Hi not sure if this is the right place for this.. 2xG Double-Glazed Back Door Translucent Glass LH uPVC 840 x 2085mm I need to know what the hinge clearance is to the edge of the frame to prevent the hinge fouling the plaster on the inside of the door opening. My existing door frame opening is only 10mm wider than the door so there is no room to play with. Thanks for any help on this
