Hi all Could someone please reccomend the best screws for putting 25mm ply down fixed to joists. I will be tiling at a later date.
A couple of 'screw and countersink' experts will be along later I'm sure Although one of them may be on a 'break' at the moment Also, ur heading says 18mm, post says 25....... which one is it
Are you talking about ceramic tiles? If so, consider using Hardie Floor - concrete based and ideal for tiling. That is, unless you already have teh ply!
3" was probably a bit overkill for 25mm, if 18mm then I agree 2" or 50mm is spot on - especially if you have them to hand!
2"/50mm is fine and if you have a surplus of bugle headed screws they should be OK if you countersink but you may have a problem with the heads snapping off as they aren't designed to go into a hard material. I don't know because I have never done it and apart from PB I have only seen them used on MFC. I've snapped plenty of good woodscrews on birch ply.
60mm 10's is my two penneth, especially if the joists aren't perfectly in line and the ply needs forcing tight to the joists to prevent movement or squeaking, no. 8 screws don't seem to have the pulling power of a meaty ten......
I tend to use 4.5's now for it's extra grip unless I think the wood might split, which isn't going to happen here.
